Godswill's avatar
Godswill
7 years ago
How to configure F5 virtual servers to ensure HSTS-compliant headers for URL are included URL
I need help on how to configure all the URLs that are rediected from my F5 to comply with HSTS compliant header. MY lTM version is 12.1.3
  • You will need to determine the best settings for HSTS for your organisation however this is an example taken from the OWASP Cheat Sheet:
    https://github.com/OWASP/CheatSheetSeries/blob/master/cheatsheets/HTTP_Strict_Transport_Security_Cheat_Sheet.md
    This example will check if the HSTS header exists, if it doesn't it will be inserted. You may wish to change the logic a bit and remove the header if it does exist to ensure consistency.
    when HTTP_RESPONSE {
        if {!([HTTP::header exists "Strict-Transport-Security"])} {
            HTTP::header insert name "Strict-Transport-Security" value "Strict-Transport-Security: max-age=86400; includeSubDomains"
    Let me know how you get on
    Lee
