bkkim_314766's avatar
bkkim_314766
May 31, 2017
How to Block signing in with a different ID in the same session ?
Hi My name is Kuk I have one question for everyone. when I block the brute force using GUI basic option also I want block Signing in with a different ID in the same session, How to configuration?
  • Hi,
    Could you please give us more details about your goal and environment?
    Thanks!
  • Hi,
    If you want to apply a policy in which you can log in with the same credentials, only once per session, I'm afraid you will not find that option in the Brute-Force (GUI) configuration.
    In order to achieve this, it is possible to use BIG-IP APM and in the access policy options configures the Max Sessions Per User value.
    I hope this helps.
    Pedro
