Amit585731
Feb 22, 2015how to add hex value in send and receive string in monitor
Hi All,
how can we add hex value in monitor send and receive field? Like for html we define below statement:
send string: GET / HTTP/1.1\r\nHost: server.com\r\n\r\n" or "GET / HTTP/1.1\r\nHost: server.com\r\nConnection: close\r\n\r\n"
receive string: 200 ok
So what will be format in hex? any example?
- nitass_89166
Noctilucent
check 0x0ff.info's reply.
TCP monitor with sending a byte sequence
https://devcentral.f5.com/questions/tcp-monitor-with-sending-byte-sequence- Amit585731
so as per forum if I want to put a value in send string so it will be something like this? \x02 \x41 \x42 \x00 correct? or do I need to define any get command etc...
- nitass
Employee
