Tyranon_113005's avatar
Tyranon_113005
Sep 17, 2018
How iRule works when a persistence adapted?
I want the HTTP access depend on uri and IPaddress.(LTM version 11.5.1) For specific client ipaddress(data group list CCclient), I want it access to poolB, others to poolA or 404 resopond.
But maybe because of persistence setting(source_addr(X-True-IP)), it doesn't access to poolB. IPaddress restriction seems adapted.
How can I ignore only when the access uri is "test.xml"? The below iRule is adapted to VS test_server which has the pool A.
if { [HTTP::header exists "X-True-IP"] } {
set clientip [HTTP::header "X-True-IP"]
set clientip [IP::client_addr]
set uri [ string tolower [HTTP::uri]]
if { $uri contains "/test.xml" } then {
if { ([class match $clientip equals CCclient]) } then {
   pool B
   HTTP::respond 404 content "404 File Not Found"
if { $uri contains "ref=trust" } {
pool B
pool A
  • You maybe have some conflicting logic here. At the very least I'd suggest inserting some logging to see how things are really being handled.
        set uri [string tolower [HTTP::uri]]
            if { ( [class match $clientip equals CCclient] ) } then {
                log local0. "uri contains /text.xml - sending to pool B"
                pool B
                log local0. "sending 404 response"
            log local0. "uri contains ref=trust - sending to pool B"
            pool B
            log local0. uri doesn't contain ref=trust - sending to pool A"
            pool A
    So basically, for it to go to pool B, the request URI has to contain "/test.xml" AND "ref=trust", and the IP has to be in the data group.
  • Dear Kevin-san,
    Thank you for your reply.
    I will set logging.
    BTW, in this case, when parsistence and iRule is adapted to VS, which does take priprity?
