mishpan_70054's avatar
mishpan_70054
Jan 28, 2013
How https monitor work ?
Like to know how the https monitor work, means what happen in background when we assigned https monitor to pool.
-Does it use Openssl command in background ?
-Does it usr curl command in background ?
-Or any other mechanism ?
Also notices that sever response do not contain any certificate in it. Please check the attached doc.
  • Have you specified a send and receive string? If not only a service check is performed (possibly why you don't see a certificate). You should configure a send and receive string to ensure the full monitor functionality is used.
    I don't believe OpenSSL or curl are used to perform the monitoring, this is a built in TMM function; however OpenSSL may be used to 'handle' the SSL if necessary.
  • Thanks for your response we do have send & receive string define but still I am seeing below mentioned handshake flow and I can see it is marking the pool member up.
    Client send -->client hello
    Server send -->Server Hello; Change Cipher Spec, Encrypted handshake message
    Client send --> Change Cipher Spec, Encrypted handshake message
    Monitor configure as:
    monitor abc.com__https_monitor {
    defaults from https
    recv " LB -Health Monitoring purposes"
    send "GET /lbhealthPage.htm HTTP/1.1\r\nHost: abc.intranet\r\nConnection: close\r\n\r\n"
  • This will be due to the SSL/TLS session being resumed. See here: http://en.wikipedia.org/wiki/Transport_Layer_SecurityResumed_TLS_handshake
  • You're welcome. I did actually try to find a way to prevent resumption on the BIG-IP for health monitors, but couldn't find anything.
  • Hi Steve
    I have one more doubt about https default monitor, i can not find any field to define CA. So how lb verify the certificate present by server
    -Does it go to /config/ssl/ssl.crt and check against each bundle ?
    And what if the certificate provide by server if self singed.
    monitorroot type https {
    defaults from none
    interval 5
    up interval 0
    timeout 16
    time until up immediate
    dest *:*
    ignore down response disable
    enable
    is read only
    partition Common
    cert none
    cipherlist "DEFAULT:+SHA:+3DES:+kEDH"
    compatibility "enabled"
    key none
    password none
    recv disable none
    recv none
    send "GET /\r\n"
    username none
  • I don't think the server certificate is validated in any way (as it would be by a browser), that's not the point of the monitor.
  • hoolio's avatar
    hoolio
    The monitor doesn't validate the server certificate to check if the service is available. If you want LTM to validate the server cert, you can configure this in a custom server SSL profile. The server cert will then be checked on load balanced connections to the pool.
    Aaron
