Ibrahim_Kadiri's avatar
Ibrahim_Kadiri
10 years ago
How do i determine SSO method
Dears,
I am configuring SSO for one of the application and i am still not sure to use which Method. I have tried all the methods one after the other but it fails.
Is there any way to determine which method will work for the application.
Thanks in Advance.
  • Hi,
    you can use curl from F5 command line:
    curl -i http://www.company.com/
    • if the code is 301 or 302, it is a redirect: follow the Location link
    • If the code returned is 401, the method can be Basic, NTLM or Kerberos, you must look at the WWW-Authenticate header
      • Basic --> basic
      • NTLM --> NTLM
      • négociante --> Kerberos
    • If the authentication page is a form, the method can be forms or forms-client-initiated.
  • hi stan,
    where do i check the information.
    i have run the command and got the below output.
  • Please do not post customer information in this forum.. the method is Forms
    to find Forms parameters to configure, I use Firefox firebug, try to authenticate with aaa login and bbb password, and search in the POST data informations.
    in you page,
    • Start URI is /newEmsg/Pages/Login.aspx
    • Form action is /newEmsg/Pages/Login.aspx
    • Form parameter for Username is ctl00%24cphBody%24Login1%24txtLoginName
    • Form parameter for Password is ctl00%24cphBody%24Login1%24txtPassword
    All other POST data must be added to Hidden form parameters with:
    One parameter per line, followed by the value (separator is space)
    to get them, you must split POST data with separator & and replace = by space.
    Some applications add dynamic parameters values to block CSRF attacks. this protection will disallow SSO.
  • Dear stan,
    i an geeting the below logs after enabling debug for sso,
    2015-10-06 14:30:58 checking start uri match, start uri: '/newEmsg/Pages/Login.aspx', request: '/newEmsg/Pages/Login.aspx' 2015-10-06 14:30:58 Websso form-based authentication for user 'abc' using config '/Common/E-messaging_Form-SSo' 2015-10-06 14:31:03 metadata len 1130 2015-10-06 14:31:03 checking start uri match, start uri: '/newEmsg/Pages/Login.aspx', request: '/newEmsg/Pages/Login.aspx' 2015-10-06 14:31:03 Websso form-based authentication for user 'abc' using config '/Common/E-messaging_Form-SSo' 2015-10-06 14:31:03 metadata len 329.
    And on the browser i am getting an error "This webpage has a redirect loop"
    Thanks for your support.
  • Dear Stan,
    I have noticed one thing in the parameter that one of the parameter value keeps on changing. Would be the reason for SSO not working?
    _VIEWSTATE (Keeps changing)
