Lotfi_Bouhaddad
May 02, 2006how Active-active Failover work
Hi
can somebody provide me with guidelines on how active-active Failover work
Thanks for your help
Lotfi
- What exactly are you asking? If you are asking about how Active-Failover works on a product level, I'd suggest you take a look at the product manual at
http://tech.f5.com
Click here
If you are asking about how to programmatically via iControl control the failover state, I'd suggest you take a look at the System::Failover interface in the SDK.
-Joe
