Vince_Beltz_959's avatar
Vince_Beltz_959
Feb 18, 2010
Hold Connection / No Pool
Got a proposal from one of our devs this AM, who wants to set up the following scenario on an LTM.
He proposes a group of clients, all trying almost constantly to connect with a VIP. The VIP allows only one connection to be established at a time, holding it until a client closes the connection or 30sec, whichever comes first. There's no data being sent over this connection, it's essentially being used as a token or signal flag (all the clients that can't get a connection freeze a parallel-processed internal task of some kind until they do make one). He sees this as the fastest way for the parallel process to communicate.
Seems fairly straightforward with Connection Limiting and a single box in a pool for the connections to go to. My question is whether there's any way for the LTM itself to hold that connection open for 30sec or until closed by the client, without requiring a server on the other side. I saw an old thread here about using OneConnect, but I don't think that's quite what I'm looking for. Or is it?
