High Speed Syslog issue
Hi All We have different Security devices (like Juniper , PA , ASA) each on different ports . We trying to load balance every syslog of every security device but infact we were failed in that like Juniper logs always will always go only on member of pool , even we use UDP stateless profile . Is there anything like irule ,that can we loadbalance the High Speed Syslog traffic ( Meanwhile we are using round robin for load balancing algorithm
- jgranieri
you will need an irule on top of a virtual server - the irule should do something like if source IP is x.x.x.x (PA src) then go to syslog_server_A and same for the remainder.
Is this what you are trying to achieve?
Hi Ashik,
to load balance individual SYSLOG messages, you have to make sure...
- Your SYSLOG client are using UDP
- Persistence profiles are disabled on your Virtual Server.
- Round Robin Load Balancing is enabled on your pool.
- Every pool member has assigned the same priority group.
- The "Datagram LB" option on your UDP profile is enabled.
If you have just enabled the "Datagram LB" option, then make sure to issue a:
tmsh delete sys connection cs-client-addr 1.2.3.4 protocol udp
Cheers, Kai
