Andy_O_4935
Oct 31, 2011High Speed logging using HSL
With the command "HSL::open -proto UDP -pool syslog_server_pool ", how exactly and where is the pool of remote syslog servers configured ?
What I understand is that syslog-ng is not used to define the server, otherwise it will defeat the purpose of High Speed Logging.
- nitass
Employee
HSL does not use syslog-ng.
the syslog_server_pool is a normal pool.
e.g.[root@iris:Active] config b pool syslog_server_pool member 1.1.1.1:514 add [root@iris:Active] config b pool syslog_server_pool list pool syslog_server_pool { members 1.1.1.1:shell {} } - Andy_O_4935
Cool. Thanks nitass !
