High Low value in System.Statistics.get_global_statistics
I've been exploring iControl System.System Info and System.Statistics and don't understand the high/low values. In some case the high value is zero while in others its not. Could some explain this to me.
(Common.Statistic){
type = "STATISTIC_CLIENT_SIDE_BYTES_IN"
value =
(Common.ULong64){
high = 9
low = -393526359
time_stamp = 0
(Common.Statistic){
type = "STATISTIC_CLIENT_SIDE_BYTES_OUT"
value =
(Common.ULong64){
high = 30
low = -1655949687
time_stamp = 0
(Common.Statistic){
type = "STATISTIC_CLIENT_SIDE_PACKETS_IN"
value =
(Common.ULong64){
high = 0
low = 191824680
time_stamp = 0
(Common.Statistic){
type = "STATISTIC_CLIENT_SIDE_PACKETS_OUT"
value =
(Common.ULong64){
high = 0
low = 219471652
time_stamp = 0
- Lots of history in that question. When we first developed iControl in 2001, the SOAP standard and encodings didn't support 64 bit numbers. To add to that, Java didn't support unsigned values so we were stuck signed ints for the high and low values (thus the negative numbers in some of them). We then had to find a way to turn our 64 bit statistic values into numbers that the various client toolkits supported. In hindsight, we probably should have also passed down a string with the 64 bit value in it.
As for the high and low values, those are the high and low 32 bits of the 64 bit number.
The calculation to convert a high and low 32bit value is this:
64 bit value = ((unsigned long)high)^32 + (unsigned long)low.
The fact that some are 0 and some aren't, just means the numbers are bigger.
Hope this helps...
-Joe - Hamish
Cirrocumulus
v11.2 perhaps ?
H - Jeremy_Mann_141
I think the formula is bit shifted, not a power of 32, given the following result:
statistics[] = (Common.Statistic){ type = "STATISTIC_CLIENT_SIDE_BYTES_IN" value = (Common.ULong64){ high = 97 low = 841866601 } time_stamp = 0 }, (Common.Statistic){ type = "STATISTIC_CLIENT_SIDE_BYTES_OUT" value = (Common.ULong64){ high = 390 low = 2041437072 } time_stamp = 0 },The formula for the result would be
value = high << 32 + lowGiving value = (97 << 32) + 841,866,601 = 417,453,694,313
The alternative would yield (97^32) + 841866601 = 3773075507922571775273744352333525624409237957166570158701128042
- Jeff_d_Ambly_24
so what is appropriate formula? should this be bit shifted? - Jason_Cohen_417Historic F5 Account
The correct formula should be to left shift the high value.
