Whoaa_aaa_14293's avatar
Whoaa_aaa_14293
Feb 26, 2014
Solved
High and low bits of 64-bit long and C#
Hi, what is the best way to take the high and low bits provided through iControl and create a 'long' in C from them?
I am currently using:
long wut = (ssl.statistics[0].value.high << 32) | ssl.statistics[0].value.low;
However, I am not sure this is how the values are intended to be used. Sometimes I am not getting the values I expect, but my expectations may be incorrect.
  • I can't help you with C, but maybe you'll be able to convert this. Here's how I do it in Python:
    def convert_to_64_bit(high, low):
        """ Converts two 32 bit signed integers to a 64-bit unsigned integer.
        if high < 0:
            high = high + (1 << 32)
        if low < 0:
            low = low + (1 << 32)
        value = long((high << 32) | low)
        assert(value >= 0)
        return value
  • For instance, using the values for STATISTIC_MEMORY_TOTAL_BYTES: ulong bl = (ulong)(val.high << 32) | (ulong)val.low; results in: High: 7 Low: -546316288 Result: 18446744073163235328 This is a crazy number and is in no way accurate. If I treat them as longs and not ulongs, the result is negative, which (again) is not accurate. Thoughts?
        if high < 0:
        if low < 0:
        assert(value >= 0)
        return value
    • Whoaa_aaa_14293's avatar
      Whoaa_aaa_14293
      I must be misunderstanding what the high and low values are then. Even when porting your code to C (which was basically just adding the if checks), I get the same exact behaviour. And I can't find any documentation detailing getting the real value out of these two high and low values.
    • mhite_60883's avatar
      mhite_60883
      Here is Joe's explanation: https://devcentral.f5.com/s/feed/0D51T00006i7P6lSAE https://devcentral.f5.com/s/articles/icontrol-apps-05-rate-based-statistics
