jj24_43946
Jun 23, 2011Help with LocalLB::VirtualServer::add_rule
Hi there,
I'm trying to apply an existing iRule to an existing monitor. Though I don't get an error, I don't see the iRules being applied.
my DS looks like this:
my @VirtualServerRules;
if ( $f5_vs_name =~ m/Https/ ) {
my $VirtualServerRule = {
rule_name => 'HA_https_splash_redirect',
priority => 1
push ( @VirtualServerRules, $VirtualServerRule );
rule_name => 'SSL_Renegotiate_Disable',
priority => 1
else {
rule_name => 'HA_http_splash_redirect',
priority => 1
my $soapResponse = $VirtualServer->add_rule
SOAP::Data->name(virtual_servers => [$f5_vs_name]),
SOAP::Data->name(rules => @VirtualServerRules),
print "iRules for virtual server $f5_vs_name applied successfully\n"
Would someone happen to have a perl sample handy for applying irules to monitors?? Thanks a lot!
- Here's how I've done it in the past.
sub addVSRule() { my ($virtual, $rulename, $priority) = (@_); if ( ("" eq $virtual) or ("" eq $rulename) or ("" eq $priority) ) { usage(); } $VirtualServerRule = { rule_name => $rulename, priority => $priority }; push @VirtualServerRuleList, $VirtualServerRule; push @VirtualServerRuleAofA, [@VirtualServerRuleList]; $soapResponse = $VirtualServer->add_rule( SOAP::Data->name(virtual_servers => [$virtual]), SOAP::Data->name(rules => [@VirtualServerRuleAofA]) ); &checkResponse($soapResponse); }
-Joe - jj24_43946
Joe, thanks so much--worked like a charm.
