DY_25487
Oct 29, 2010Help with iRule
Hi,with writing iRules and it would be great to get some tips on where to start.
I am a beginner
My requirements are i need to do a health check against a web server by doing HTTP get on a file (blah.pac) and checking for a string within the file. If the string is there then the server is available if not then bring the server down.
Any help would be greatly appreciated.
Regades,
David
- hoolio
Hi David,
You can use a health monitor to do this. You can check the LTM config guide for your version on AskF5.com to get details on how to do this.
Aaron
