ikkut23's avatar
ikkut23
Sep 21, 2024
Help with iRule Proxy
Hi team,
I’m working on an iRule where I need to replace the path /admin with the root / and forward the request to the appropriate pool. However, I’m encountering issues with the rule, and it doesn't seem to work as expected.
Here’s the first version I implemented:
when HTTP_REQUEST
 { if {[string tolower [HTTP::host]] equals "test.com" and [HTTP::path] starts_with "/admin"} { HTTP::path [string map -nocase {"/admin" "/"} [HTTP::path]] pool POOL-A #log local0.info "Client Address --> [IP::client_addr] | Path: [HTTP::path] | Pool: POOL-A" } else { pool POOL-B #log local0.info "Client Address --> [IP::client_addr] | Path: [HTTP::path] | Pool: POOL-B" } }
After some research, I saw that HTTP::path might need to be changed to HTTP::uri. I tried this version:
when HTTP_REQUEST { # Log the original URI for debugging log local0. "Original URI: [HTTP::uri]" # Check if the URI starts with "/admin" if {[HTTP::uri] starts_with "/admin"} { # Modify the URI by replacing "/admin" with "/" set new_uri [string map {"/admin" "/"} [HTTP::uri]] HTTP::uri $new_uri # Log the modified URI for debugging log local0. "Modified URI: [HTTP::uri]" # Forward the request to the appropriate pool pool POOL-A } else { # Log default traffic for debugging log local0. "Default traffic - URI: [HTTP::uri], Pool: POOL-B" # Forward to the default pool pool POOL-B } }
Issue:
Neither version seems to work. When I test requests to /admin, the path replacement does not happen as expected or The replace of path does not allow me to reach any subfolders after root “/” (ex. help, etc etc) and on these objects we faced 404 not found error.Could someone point out what I might be missing or any best practices for this kind of path manipulation?
Thanks!
  • when HTTP_REQUEST {
    if { [HTTP::path] equals "/" } {
    HTTP::redirect "http://www.domian.com/base/"
