Dbow_21284
Aug 18, 2009Help with External HTTP Monitor (cURL) - Requires http authentication
Hello,
I am taking a variation of an external monitor used when NTLM auth is required and tweaking it for jsut regular http authentication. However, I am having an issue getting it to work entirely. When I run the external monitor from an SSH CLI (for instance, sh -x /usr/bin/monitors/AUTH_Members 10.10.185.40 80 ) I get the appropriate response, but when I apply the monitor to a pool in the MGMT GUI, it does not work.
My External monitor code is below and is testing return string of "1-UP":
!/bin/sh
remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)
IP=`echo ${1} | sed 's/::ffff://'`
IP=${1}
PORT=${2}
PIDFILE="/var/run/`basename ${0}`.${IP}_${PORT}.pid"
kill of the last instance of this monitor if hung and log current pid
if [ -f $PIDFILE ]
then
kill -9 `cat $PIDFILE` > /dev/null 2>&1
fi
echo "$$" > $PIDFILE
send request & check for expected response
curl -L -v --user 'testuser:superpassword' http://${IP}:${PORT}/_layouts/ACCApplications/CommonLogin/login.aspx?ReturnUrl=%2fwhatsup.aspx -H "Host: members.acc.org" | grep -i "1-UP"
2>&1 > /dev/null
mark node UP if expected response was received
if [ $? -eq 0 ]
then
echo "UP"
fi
rm -f $PIDFILE
exit
When I execute it in the CLI with command, sh -x /usr/bin/monitors/AUTH_Members 10.10.185.40 80, it seems to work! See below:
[admin@dmzlb1:Active] monitors sh -x /usr/bin/monitors/AUTH_Members 10.10.185.40 80
++ echo 10.10.185.40
++ sed s/::ffff://
+ IP=10.10.185.40
+ PORT=80
++ basename /usr/bin/monitors/AUTH_Members
+ PIDFILE=/var/run/AUTH_Members.10.10.185.40_80.pid
+ '[' -f /var/run/AUTH_Members.10.10.185.40_80.pid ']'
+ echo 9294
+ curl -L -v --user testuser:superpassword 'http://10.10.185.40:80/_layouts/ACCApplications/CommonLogin/login.aspx?ReturnUrl=%2fwhatsup.aspx' -H 'Host: members.acc.org'
* About to connect() to 10.10.185.40 port 80
* Trying 10.10.185.40... + grep -i 1-UP
connected
* Connected to 10.10.185.40 (10.10.185.40) port 80
* Server auth using Basic with user 'testuser'
> GET /_layouts/ACCApplications/CommonLogin/login.aspx?ReturnUrl=%2fwhatsup.aspx HTTP/1.1
> Authorization: Basic ZGRlbmJvdzpiYWJ5cmVuMQ==
> User-Agent: curl/7.15.3 (i686-redhat-linux-gnu) libcurl/7.15.3 OpenSSL/0.9.7l zlib/1.1.4
> Accept: */*
< HTTP/1.1 200 OK
< Date: Tue, 18 Aug 2009 21:05:43 GMT
< Server: Microsoft-IIS/6.0
< X-Powered-By: ASP.NET
< MicrosoftSharePointTeamServices: 12.0.0.6510
< X-AspNet-Version: 2.0.50727
< Cache-Control: private
< Content-Type: text/html; charset=utf-8
< Content-Length: 21385
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 21385 100 21385 0 0 940k 0 --:--:-- --:--:-- --:--:-- 4579k* Connection 0 to host 10.10.185.40 left intact
* Closing connection 0
+ '[' 0 -eq 0 ']'
+ echo UP
UP
+ rm -f /var/run/AUTH_Members.10.10.185.40_80.pid
+ exit
Has anyone ever seen this or experienced this? Or any ideas where to go on this? I have verified the member IP addresses in the pool are right. So unfortunately, its not something simple like this.
Also, I tried a stock HTTP monitor via the GUI with the following configuration which didnt work either, which is why I went to the external monitor:
GET /_layouts/ACCApplications/CommonLogin/login.aspx?ReturnUrl=%2fwhatsup.aspx HTTP/1.1\nHost: members.acc.org \nConnection: close\n\n
Then I put the username and password in their respective fields in the properties of the monitor in the LTM GUI. That didnt work either.
Thanks,
Dbow
- Kevin_Stewart
Employee
To get the status code, you need the cURL write-out option. Example: ret=`curl -fNs http://10.70.0.1 -w "%{http_code}" -o /dev/null`
