Dbow_21284's avatar
Dbow_21284
Aug 18, 2009
Help with External HTTP Monitor (cURL) - Requires http authentication
Hello,
I am taking a variation of an external monitor used when NTLM auth is required and tweaking it for jsut regular http authentication. However, I am having an issue getting it to work entirely. When I run the external monitor from an SSH CLI (for instance, sh -x /usr/bin/monitors/AUTH_Members 10.10.185.40 80 ) I get the appropriate response, but when I apply the monitor to a pool in the MGMT GUI, it does not work.
My External monitor code is below and is testing return string of "1-UP":
 !/bin/sh
  remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)
 IP=`echo ${1} | sed 's/::ffff://'`
  IP=${1}
 PORT=${2}
 PIDFILE="/var/run/`basename ${0}`.${IP}_${PORT}.pid"
  kill of the last instance of this monitor if hung and log current pid
 if [ -f $PIDFILE ]
 then
 kill -9 `cat $PIDFILE` > /dev/null 2>&1
 fi
 echo "$$" > $PIDFILE
  send request & check for expected response
 curl -L -v --user 'testuser:superpassword' http://${IP}:${PORT}/_layouts/ACCApplications/CommonLogin/login.aspx?ReturnUrl=%2fwhatsup.aspx -H "Host: members.acc.org" | grep -i "1-UP"
 2>&1 > /dev/null
  mark node UP if expected response was received
 if [ $? -eq 0 ]
 then
 echo "UP"
 fi
 rm -f $PIDFILE
 exit
When I execute it in the CLI with command, sh -x /usr/bin/monitors/AUTH_Members 10.10.185.40 80, it seems to work! See below:
 [admin@dmzlb1:Active] monitors  sh -x /usr/bin/monitors/AUTH_Members 10.10.185.40 80
 ++ echo 10.10.185.40
 ++ sed s/::ffff://
 + IP=10.10.185.40
 + PORT=80
 ++ basename /usr/bin/monitors/AUTH_Members
 + PIDFILE=/var/run/AUTH_Members.10.10.185.40_80.pid
 + '[' -f /var/run/AUTH_Members.10.10.185.40_80.pid ']'
 + echo 9294
 + curl -L -v --user testuser:superpassword 'http://10.10.185.40:80/_layouts/ACCApplications/CommonLogin/login.aspx?ReturnUrl=%2fwhatsup.aspx' -H 'Host: members.acc.org'
 * About to connect() to 10.10.185.40 port 80
 *   Trying 10.10.185.40... + grep -i 1-UP
 connected
 * Connected to 10.10.185.40 (10.10.185.40) port 80
 * Server auth using Basic with user 'testuser'
 > GET /_layouts/ACCApplications/CommonLogin/login.aspx?ReturnUrl=%2fwhatsup.aspx HTTP/1.1
 > Authorization: Basic ZGRlbmJvdzpiYWJ5cmVuMQ==
 > User-Agent: curl/7.15.3 (i686-redhat-linux-gnu) libcurl/7.15.3 OpenSSL/0.9.7l zlib/1.1.4
 > Accept: */*
 < HTTP/1.1 200 OK
 < Date: Tue, 18 Aug 2009 21:05:43 GMT
 < Server: Microsoft-IIS/6.0
 < X-Powered-By: ASP.NET
 < MicrosoftSharePointTeamServices: 12.0.0.6510
 < X-AspNet-Version: 2.0.50727
 < Cache-Control: private
 < Content-Type: text/html; charset=utf-8
 < Content-Length: 21385
 % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
 Dload  Upload   Total   Spent    Left  Speed
 100 21385  100 21385    0     0   940k      0 --:--:-- --:--:-- --:--:-- 4579k* Connection 0 to host 10.10.185.40 left intact
 * Closing connection 0
 + '[' 0 -eq 0 ']'
 + echo UP
 UP
 + rm -f /var/run/AUTH_Members.10.10.185.40_80.pid
 + exit
Has anyone ever seen this or experienced this? Or any ideas where to go on this? I have verified the member IP addresses in the pool are right. So unfortunately, its not something simple like this.
Also, I tried a stock HTTP monitor via the GUI with the following configuration which didnt work either, which is why I went to the external monitor:
 GET /_layouts/ACCApplications/CommonLogin/login.aspx?ReturnUrl=%2fwhatsup.aspx HTTP/1.1\nHost: members.acc.org \nConnection: close\n\n
Then I put the username and password in their respective fields in the properties of the monitor in the LTM GUI. That didnt work either.
Thanks,
Dbow
