Ted_Smith_11168's avatar
Ted_Smith_11168
Aug 09, 2005
help with cookie expiration in iRule
I have two iRules listed below. We are injecting a cookie on siteA, the redirecting to siteB. SiteB checks for value set in siteA. If it is there allow user access. If not go back to siteA and get value set.
We don't want people bookmarking and accessing siteb directly.
How can I specify a expiration time on the cookie we are setting through the iRule?
iRule set for www.companya.com VIP
when CLIENT_ACCEPTED {
  set ckname www1
  set ckvalue [IP::client_addr]
  set ckdomain companya.com
  set cookie [format "%s=%s; path=/; domain=%s" $ckname $ckvalue $ckdomain]
when HTTP_RESPONSE {
  HTTP::respond 302 Location "https://www1.companya.com" "Set-Cookie" $cookie
iRule set for www1.companya.com VIP
  set ckname www1
  if {[HTTP::cookie exists $ckname]} {
    pool UITShared
  else {
    HTTP::redirect "https://www.companya.com"
Thanks!
  • The Set-Cookie header is specified in RFC 2109 - HTTP State Management Mechanism (Click here).
    4.2.2  Set-Cookie Syntax
       The syntax for the Set-Cookie response header is
       set-cookie      =       "Set-Cookie:" cookies
       cookies         =       1cookie
       cookie          =       NAME "=" VALUE *(";" cookie-av)
       NAME            =       attr
       VALUE           =       value
       cookie-av       =       "Comment" "=" value
                       |       "Domain" "=" value
                       |       "Max-Age" "=" value
                       |       "Path" "=" value
                       |       "Secure"
                       |       "Version" "=" 1*DIGIT
    Looks like you'll want to use the "Max-Age" value that's defined as follows:
    Max-Age=delta-seconds
    Optional. The Max-Age attribute defines the lifetime of the
    cookie, in seconds. The delta-seconds value is a decimal non-
    negative integer. After delta-seconds seconds elapse, the client
    should discard the cookie. A value of zero means the cookie
    should be discarded immediately.
    In Netscapes original proposal, there is also an "Expires" header that believe most browsers still support which takes as an argument a date string.
    -Joe
  • Thanks Joe, you are always very helpful (even when it is not a specific iRule question)!
    I am having an issue with the rule mentioned above and was wonering if you could add some insight as to what I am missing.
    The above iRules work when a user goes to the default site. if the user types in a custom uri, it doesn't work. I altered the rules to read the uri and append it to the redirect command.
    I don't think the cookie is being set or seen properly somewhere along the way because then I enter am infinite loop between the two Irules. Why would the cookie work with no uri, but not work when uri is appended?
    Any advice on altering the irule or debugging with some log commands?
    Thanks again for your help!!
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    I think you might want your cookie domain to be ".companya.com".
    From RFC2109:
    4.3.2 Rejecting Cookies
    To prevent possible security or privacy violations, a user agent
    rejects a cookie (shall not store its information) if any of the
    following is true:
    * The value for the Path attribute is not a prefix of the request-
    URI.
    * The value for the Domain attribute contains no embedded dots or
    does not start with a dot.
    * The value for the request-host does not domain-match the Domain
    attribute.
    * The request-host is a FQDN (not IP address) and has the form HD,
    where D is the value of the Domain attribute, and H is a string
    that contains one or more dots.
    Examples:
    * A Set-Cookie from request-host y.x.foo.com for Domain=.foo.com
    would be rejected, because H is y.x and contains a dot.
    * A Set-Cookie from request-host x.foo.com for Domain=.foo.com would
    be accepted.
    * A Set-Cookie with Domain=.com or Domain=.com., will always be
    rejected, because there is no embedded dot.
    * A Set-Cookie with Domain=ajax.com will be rejected because the
    value for Domain does not begin with a dot.
  • I have made the change to the cookie domain, but I am still getting strange (unexplained and unwanted) results.
    If I use a url with https://hostname.domain.com/ it seems to work. Webserver sends request to Coldfusion MX appserver, which sets default uri ( a logon page). Cookie seems to work properly.
    If I enter a different url https://hostname.domain.com/admin/logon.cfm, the irule is caught in infinite forwarding loop.
    I gotta be missing something simple. I 'm going to keep plugging away. We have an entire web farm migration hinged on getting this to work.
    Is this the proper place for this or should I open a support ticket?
    Thanks again for everyone's help!!
    unRuleY_95363
    Historic F5 Account
    Maybe you should post your current (desensitized) version of the rule with the uri stuff you added. Maybe there's something broken in that?!?
    And, yes, this is probably the correct place for this as it doesn't appear that anything is actually broken with the Bigip. It seems more like a matter of figuring out how to get it working with your deployment.
  • This is in an internal QA Environment:
    VIP uitaac.allied.nwie.net
            set ckname uitaac1
            set ckdomain .allied.nwie.net
    when HTTP_REQUEST  {
            set uri [HTTP::uri]
            HTTP::respond 302 Location "https://uitaac1.allied.nwie.net$uri]" "Set-Cookie" $cookie
    VIP uitaac1.allied.nwie.net
            set ckname uitaac1
            set uri [HTTP::uri]
            pool UITShared
         else {
            HTTP::redirect "https://uitaac.allied.nwie.net$uri"
    Thanks!
    unRuleY_95363
    Historic F5 Account
    Either this is a cut-n-paste error or perhaps your problem, but you have a closing square bracket ']' at the end of the uri in your first rule. Is that intended?
  • No it was not intended. Not sure how I missed it. Probably a typo from the 30 or so different things I have tried the last two days.
    Good news is that after correcting this embarrassingly obvious mistake, things seem to be running very smooth.
    I need to do more extensive testing over the next few days, but this is finally the break I have been working for the last few days.
    Thanks again for all your help. Hopefully I won't be posting on this issue in the near future :-)
