rdessert_76127
Jul 19, 2012Help with adding mobile redirect to existing irule
Hi all,
I have been asked to redirect a handful of mobile device types (user agents) to our mobile homepage and am having some trouble getting the irule configured properly.
My current homepage irule is as follows:
if { [HTTP::host] equals "site.com" } {
HTTP::respond 301 Location "http://www.site.com[HTTP::uri]"
return
log local0.alert "BEGIN Host:[HTTP::host]-[HTTP::uri]-[HTTP::path]"
switch -glob [string tolower [HTTP::uri]] {
"/foo/*" -
"/news/*" -
"/sites/*" -
"/node/*"
log local0.alert "op_pool Host:[HTTP::host]-[HTTP::uri]"
pool op_pool
return
default {
pool def_pool
I need to redirect the following user agents to http://m.site.com
blackberry
wp7
iphone
androi
Any suggestions on how / where to add the mobile redirect. I'm thinking it needs to go at the beginning but don't know the best syntax.
Thanks for any help!!
Rich
- nitass
Employee
e.g.[root@ve10:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.79:80 ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve10:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { if {[HTTP::host] equals "site.com"} { if {[class match -- [string tolower [HTTP::header value "User-Agent"]] equals mobile_class]} { HTTP::respond 301 Location "http://m.site.com[HTTP::uri]" } else { HTTP::respond 301 Location "http://www.site.com[HTTP::uri]" } } else { switch -glob [string tolower [HTTP::uri]] { "/" - "/*" - "/\\?*" - "/foo/*" - "/news/*" - "/sites/*" - "/node/*" { pool op_pool } default { pool def_pool } } } } } [root@ve10:Active] config curl -I http://172.28.19.79/something -H "Host: site.com" HTTP/1.0 301 Moved Permanently Location: http://www.site.com/something Server: BigIP Connection: Keep-Alive Content-Length: 0 [root@ve10:Active] config curl -I http://172.28.19.79/something -H "Host: site.com" -H "User-Agent: iphone" HTTP/1.0 301 Moved Permanently Location: http://m.site.com/something Server: BigIP Connection: Keep-Alive Content-Length: 0 - rdessert_76127
Thanks nitass, I will give this a shot.
Rich - rdessert_76127
Works like a champ, thanks again nitass. - rdessert_76127
When I tested this with a browser it wasn't working although it was working by running the curl command from the box itself. I ended up having to change this line as follow...
to
if {[class match -- [string tolower [HTTP::header value "User-Agent"]] contains mobile_class]} {
Had me scratching my head for a bit, but it finally clicked :-)
Rich
