Help with a http health monitor
Hi All
I want to implement a simple health monitor (HTTP) to my ADFS 2012 R2 servers (a new probe shipped in a Windows update to this OS). All I need to do is make a http get request to the below URL and ensure I get a http 200 OK code in return.
http:///adfs/probe
I am running F5 LTM VE 11.6.1
Thanks!
- mr_evil_116524
You will need to create a custom HTTP monitor and use the following string
Sending String - HEAD HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n
Receive String -HTTP/1.1 200 OK
- Gurdip_Sira_160
Thanks! So everything after the - . Any GET required?
The other question I had was I havr two ADFS (the application is ADFS 2012 R2), as the hostname obviously is different for both servers, I would need two health monitors ..... is there any workaround to keep one health monitor? Out of interest.
- mr_evil_116524
You can use one health monitor for two servers. You will need to put the two server under one Pool and assign the custom monitor the Pool. As far as GET that depends on that you trying to do ... but from what I can see you dont need to use any GET at this point of time.
- Jinshu
Cirrus
try this.. for create a generic external monitor fot http.
https://devcentral.f5.com/codeshare?sid=395
- mikeshimkus_111Historic F5 Account
Gurdip,
ADFS 3.0 requires SNI, which isn't supported by our built-in HTTPS monitors. Check the ADFS deployment guide for info on how to create an external EAV monitor to check the availability of the servers:
Mike
