Julian_Sierra_4
Jun 10, 2011Help me with exchage2010 in F5 v 10.2.1
Hello every one... I am setting exchange 2010 on BIG-IP 10.2.1 Build 511.0 Hotfix HF3, following the Deployment Guide http://www.f5.com/pdf/deployment-guides/f5-exchange-2010-dg.pdf. I am use the Template for Exchange 2010, this template generate an iRule named Exch_2010_single_Persist_irule (view original iRule in the pag 56 of deployment guide).
iRule to select pool and persistence method when all Exchange
Client Access services are accessed through the same BIG-IP
virtual server.
switch -glob [HTTP::path] {
"/Microsoft-Server-ActiveSync*" {
Direct all ActiveSync clients to a common pool; use
HTTP cookie persistence
persist cookie
pool Exch_2010_single_as_pool
log local0. "host [HTTP::host] url [HTTP::uri] Persistencia"
HTTP::class disable
"/rpc/rpcproxy.dll" {
Grab all requests for Outlook Anywhere; the following
checks assign correct persistence methods.
switch -glob [HTTP::header "User-Agent"] {
"MSRPC" {
This User-Agent section matches most versions of
Outlook and Windows using Outlook Anywhere.
The OutlookSession cookie is new to Outlook 2010.
if { [HTTP::cookie exists "OutlookSession"] } {
persist uie [HTTP::header "OutlookSession"] 3600
else {
persist uie [HTTP::header "Authorization"] 3600
"*Microsoft Office*" {
This section matches some versions of
Outlook 2007 on Windows XP
default {
This section catches all other requests for
Outlook Anywhere, and sets a persistence method
that does not require the client to support
HTTP cookies
persist source_addr
Finally, this assigns the Outlook Anywhere pool and turns
off full HTTP parsing and compression. If the preceding
clients should be sent to separate pools, the pool statement
should be removed here, and a separate pool statement
placed in each of the preceding logic branches.
Other modules (APM, ASM, etc.) should be disabled here
as well, if active for other traffic though this virtual
server.
pool Exch_2010_single_oa_pool
HTTP::disable
COMPRESS::disable
CACHE::class disable
log local0. "host [HTTP::host] url [HTTP::uri] Anyware"
"/xml/autodiscover.aspx" {
Requests for Autodiscovery information. The selected pool
might be unique, or might be the same as e.g. your pool
for OWA or ActiveSync. In this example, we use the same
pool that receives ActiveSync traffic.
persist cookie
log local0. "host [HTTP::host] url [HTTP::uri] AuteSync"
HTTP::class disable
default {
This final section takes all traffic that has not
otherwise been accounted for and sends it to the
pool for Outlook Web App
persist cookie
pool Exch_2010_single_owa_pool
log local0. "host [HTTP::host] url [HTTP::uri] Owa"
If using the Web Accelerator module, uncomment the
following line and change the name to that of
your WA class.
HTTP::class select Exch_2010_class
log local0. "host [HTTP::host] url [HTTP::uri] WebAcelerator"
Checking logs, found the next error
Jun 10 10:26:51 local/tmm err tmm[5201]: 01220001:3: TCL error: Exch_2010_single_Persist_IRule_irule - Prerequisite operation not in progress (line 1) invoked from within "HTTP::host" ("/rpc/rpcproxy.dll" arm line 51) invoked from within "switch -glob [HTTP::path] { "/Microsoft-Server-ActiveSync*" { Direct all ActiveSync clients to a common pool; use ..."
Any idea...?
- Did you by any chance try to create a new iRule by cutting and pasting from the deployment guide and see if the syntax error persists?
- Julian_Sierra_4
Yes, I am try create new iRule, but the error persist... :(. Thank You - hoolio
Do you have a default pool on the virtual server? If not, try adding one to see if the error goes away.
http://devcentral.f5.com/wiki/default.aspx/iRules/persist
When using the session or persist commands, one common error that occurs is "Prerequisite operation not in progress". The most common cause for this error is that there is no pool currently selected for the connection. Persistence and session entries by default are limited to a single pool. For most virtual servers, a default pool is specified in bigip.conf, and this pool will be used when persistence or session queries are made. Selecting a default pool to use is usually the best way to eliminate this error. If you cannot specify a default pool (for example, with a forwarding virtual), then you can specify that the operation should be across all pools using the any pool option described above.
Aaron - hoolio
Also, make sure to add a OneConnect profile to the virtual server if you haven't already. If you're using SNAT you can add the default OneConnect profile with a /0 source mask. If not create a custom OneConnect profile with a /32 source mask.
Aaron - Julian_Sierra_4
Aron, thank you very much for you help... I checking configuration for virtual server and look what profile use for the virtual server is, One Connect... The configuration for me virtual server is
virtual Exch_2010_single_https_virtual_server {
snat automap
destination 10.26.1.30:https
ip protocol tcp
rules {
Exch_2010_single_append_irule
irule_pop-up_excha_2010
persist Exch_2010_single_persist_profile
profiles {
Exch_2010_single_clientssl_profile {
clientside
Exch_2010_single_lan-optimized_tcp_profile {
serverside
Exch_2010_single_ntlm_profile {}
Exch_2010_single_one_connect_profile {}
Exch_2010_single_wan-optimized_tcp_profile {
clientside
microsoft_exchange_2010_https_http-wan-optimized-compression_shared_http {}
Was taken configuration file from bigip.conf... I can change some parameter in the virtual server...? The problem persist - hoolio
Can you set the virtual server to use the Exch_2010_single_owa_pool pool under the virtual server resources tab? The iRule can select other pools based on the logic in the rule. But having a default pool on the virtual server should avoid the runtime error you're seeing.
Aaron - Two more questions: did you modify the configuration after running through the template at all, and what are the symptoms other than the message logged? Is traffic flowing through the box, or is the message indicative of the connections being interrupted? What client type is accessing Exchange when the message is logged?
