Help for when_http_response
when HTTP_REQUEST timing on priority 100 {
Check the requested path with wildcard matching
switch -glob [HTTP::path] {
"/appmania*" {
log local0. "HOST [HTTP::host] PATH [HTTP::path]"
pool HTTP_appmania
"/floo*" {
pool HTTP_floo
"/HARDWARE*" {
switch [string tolower [IP::client_addr]] {
"85.88.99.201" {
log local0. "1 [HTTP::uri] [IP::client_addr] "
pool HTTP_active
log local0. " [HTTP::uri] [IP::client_addr] "
"85.87.66.78" {
pool HTTP_active
"85.74.86.89" {
pool HTTP_active
"92.78.96.129" {
pool HTTP_active
"92.78.96.129" {
pool HTTP_active
default
pool HTTP_active
pool HTTP_active
I need your help about the above irule. we want to produce log the "/HARDWARE*" { responses on the f5. Could you help us ?
Thank you in advance.
regards,
