Rodolphe_AUBINE
May 24, 2011HELP ASM subsystem error - Failed to send command to DCC... force to reboot while importing XML policy with intern wdsl definitions
When I try to import a XML policy(which is just exported from destination) with GUI, the ASM module log an error :
May 24 09:36:33 local/fwi-qsips-vdm05 crit perl[7075]: 01310027:2: ASM subsystem error (nwd.pl,F5::NwdUtils::VerifyDcc::get_dms_status): Failed to send command to DCC...
The GUI is "waiting for few minutes"...
The SSH access is down...
and then...a reboot appears....COOL !
May 24 09:41:32 boot_marker: ---===[ HD1.1 - BIG-IP 10.1.0 Build 3402.0 ]===---
May 24 09:44:54 local/fwi-qsips-vdm05 info set_ibdata1_size.pl[5926]: Setting ibdata1 size finished successfully, a new size is: 8466M
May 24 09:45:02 local/fwi-qsips-vdm05 notice (ts_proc)recovery_mngr.pl[3640]: (0)(INIT_OK): ASM initialization started
May 24 09:45:31 local/fwi-qsips-vdm05 info perl[3640]: 01310028:6: ASM subsystem info (recovery_mngr.pl,main::handle_agent_msg): ASM initialized successfully
May 24 09:45:32 local/fwi-qsips-vdm05 debug tsconfd[6248]: mcpd_bridge_thread started
May 24 09:45:33 local/fwi-qsips-vdm05 notice dcc[6248]: 01310022:5: ASM started successfully
Question : why ? even if th policy I try to import is an exported one, from this BigIP !!!!
Complementary informations :
- BIG-IP 10.1.0 Build 3402.0 Hotfix HF2
- This policy is defined for 2 WS Soap with 2 wdsl definitions yet imported and stored in
Thaks in advance for your help..
Rodolphe AUBINEAU
(France)
- hoolio
Hi Rodolphe,
I suggest opening a case with F5 Support on this issue.
Aaron
