deeje_115970's avatar
deeje_115970
Sep 25, 2014
Health monitor for pool members with servers using multiple ports
First, I know this is not a very clear explanation but i'll try my best
Goal: Pool members will be marked inactive if health check end point returns !200.
Pool setup: The pool members pass traffic via 11111 but the health status endpoints live on a different port -- 11117
Snippet of pool members:
node1 service port=11111 manage port=11117
node1 service port=11121 manage port=11127
node1 service port=11131 manage port=11137
node2 service port=11111 manage port=11117
node2 service port=11121 manage port=11127
node2 service port=11131 manage port=11137
Is there a way to use a health monitor that could look at the nodes port and substitute a digit. For example, the health monitor looks at pool member node1:11111 and knows to check port 11117?
I tried adding 3 health monitors looking at each port, 11117,11127, 11137, and setting the availability requirement to 2. That doesn't work because a pool member's port could be down but the other 2 are up so it doesn't mark the actual pool member down.
Here is one of the health monitors i've set up
ltm monitor http myapp_11117 {
defaults-from http7
destination *:11117
interval 5OK"
recv "200 OK"nage/status HTTP/1.1\r\nHost: localhost\r\nConnection: Close\r\n\r\n"
send "GET /manage/status HTTP/1.1\r\nHost: localhost\r\nConnection: Close\r\n\r\n"
time-until-up 0
timeout 16
Open to any all and all suggestions that include solutions outside of the F5.
  • you can make use of Alias Service Port setting of the health monitors to address your requirement. Thanks!
  • I tried adding 3 health monitors looking at each port, 11117,11127, 11137, and setting the availability requirement to 2.
    didn't you assign the health monitor to pool member level (rather than pool level)?
