Abhinav5656's avatar
Abhinav5656
Apr 21, 2020
Health check on F5 Load Balancer
How people perform the health check on F5 device?
What kind of command or API will be use in order to check the health of F5 device ?
It would be helpful for me if anyone can help me.
Regards
  • You can use below commands to check status/health of F5 device.
    tmsh show sys cpu --- Check cpu status
    tmsh show sys connection ---- check current open connections
    tmsh show sys memory --- Check memory usage
    df -h --- Check memory usage
    tmsh show sys hardware --- Check hardware status
    tmsh show cm failover-status – Check HA/Failover status
    tmsh show sys traffic – Traffic Statistics
    tmsh show cm sync-status ---- Check sync status
    tmsh show cm traffic-group --- Check Traffic-Groups
    uptime --- Check F5 device uptime
    tmsh show ltm virtual --- Check connection status on VS
    tmsh show sys ha-status --- Check HA status
    tmsh show sys service --- Check all services status and up time.
    tmsh show sys availability --- Check system availability status
    Hope it helps!
    Mayur
