HA problem v11.2.0
Hi all,
I’m pretty new in F5, so I’m a bit losing with configuration and troubleshooting with two boxes in v11.2.0. My problem is trying to create a HA pair.
I have one pair (A & B) with the following configuration
F5-A
Interface management= 1.1.1.1
Interface 1.1 = 2.2.2.1, vlan x untagged external, traffic-group-local-only
Interface 1.2 = 3.3.3.1, vlan y tagged internal, traffic-group-local-only
Interface 1.3 = 192.168.1.1 , vlan z untagged for sync, traffic-group-local-only
Floating IP=1.1.1.3 , traffic-group-1
Floating IP=2.2.2.3 , traffic-group-1
F5-B
Interface management= 1.1.1.2
Interface 1.1 = 2.2.2.2, vlan x untagged, traffic-group-local-only
Interface 1.2 = 3.3.3.2, vlan y tagged, traffic-group-local-only
Interface 1.3 = 192.168.1.2 , vlan z untagged, traffic-group-local-only
This configuration was created with the setup wizard. Both devices are directly connected via ports 1.3 (I’ve read this is possible)
In F5-A I can see this log message:
Attempting to connect to CMI peer 192.168.1.2 port 6699
CMI reconnect timer: enabled
Can't connect to CMI peer 192.168.1.2, port:6699, Transport endpoint is not connected
In F5-B I can see this log message:
Attempting to connect to CMI peer 192.168.1.1 port 6699
Can't connect to CMI peer 192.168.1.1, port:6699, Transport endpoint is not connected
Any idea?
Thanks in advance!
- Kevin_Stewart
Employee
What are your port lockdown settings on your 192.168.1.x Self-IPs? - pentax_120347
Allow default
- Kevin_Stewart
Employee
Have you reviewed this document?
sol13946: Troubleshooting ConfigSync and device clustering (11.x)
http://support.f5.com/kb/en-us/solutions/public/13000/900/sol13946.html?sr=30172557 - pentax_120347
Yes I do.
If I go to F5-A I can see in the Device management the box A Up and the B offline (but I can see his managemnt addres, his hostname and his version)
If I go to F5-B I can see in the Device management the box B Up and the A unknow state (I cannot see his managemnt addres, his hostname and his version) - Kevin_Stewart
Employee
Can you:
1. Run netstat -pan | grep -E 6699 on each device and confirm that the list looks the same on each, and
2. Run a tcpdump and see if either of the devices is rejecting any traffic on any port between the two. - HHeredia_36237
kinda miss the old HA configuration :(
try to get the second box off the cluster (device mgmt menu) and then add it again.
Also try changing the port lockdown settings to Allow All, while troubleshooting this issue.
good luck - Albert_59847
Dear,
Open a case, F5 engineers will help you. read below links you might miss something.
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos_management_guide_10_1/tmos_high_avail.html
http://support.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/product/relnote-ltm-11-2-0.html
