GUI(https) Login Failure ,Same username/password works for TMSH.
Im having a weird problem of fail to login to F5 via GUI(Https) ,but where the same username and password credentials works well for TMSH(CLI) login is.
Have reset the the password couple of time.BUt still no luck to login via GUI.
Any help on this be much appreciated.
Regards,
Jibin
- kunjan_118660
Cumulonimbus
Are you using root? How do you reset? Using GUI? What's the role for the id?
- Jibinpv
Hi Kunjan, Sorry I hadn't made it clear.
Have done the reset using root. And post reset I was able to login to TMSH with the latest password.
The role of the ID is admin.
- kunjan
- Jibinpv
- kunjan_118660
Cumulonimbus
Try using GUI to reset the password. Do note the user id is admin not root.
- Jibinpv
Hi Kunjan - Im sorry didn't get thatyou are trying to say. Would you mind to please have that elaborated.
- kunjan_118660
Cumulonimbus
Can you login using user id 'admin' in the GUI?
- Jibinpv
Well NO - thats where im facing the problem. THis is how I have done the password reset with root via CLI
modify auth user Admin prompt-for-password
changing password for Admin
new password:
confirm password:
Post this I was able to login successfully to TMSH with Admin - Again not to GUI.
auth user Admin {
description Admin encrypted-password XXXXXXXXXXXXXX partition Common partition-access { all-partitions { role admin } } shell bash}
- kunjan
- Jibinpv
- kunjan
- Jibinpv
new password:
confirm password:
auth user Admin {
