sky_chen's avatar
sky_chen
Dec 12, 2019
GTM load ucs issue
The question is which name to change? , thanks.
  • Surgeon's avatar
    Surgeon
    Ret. Employee
    build in bind server is not able to start. One of the possible reason syntax error in zone or bind config file.
    I recommend you to open a support case
    • Lidev's avatar
      Lidev
      Hello sky_chen,
      is it possible to kown how have you solve you issue ? you have made changes on your configuration zone file ?
      it'll probably help someone who's facing the same mistake 😉
      • sky_chen's avatar
        sky_chen
        I go to f5 command-line , show history , view previous history information , and then build a file on the issue.😭
