Ruggerfly1's avatar
Ruggerfly1
Aug 20, 2012
GTM 9.4.8 HF6 mcpd memory leak
Good morning
Been chasing a memory leak in the mcpd process; upgraded to HF6 from HF4 to address, but no joy.
other symptoms:
gtmparse wideip.conf timed out
SYNC wideip.conf skipped. Reason: gtmparse running - seems to be stuck in the attempt.
This is a standalone unit in a sync group. the other unit in the group is running fine.
Was thinking about trying a gtm_add.
Any direction would be greatly appreciated.
thanks
  • hoolio's avatar
    hoolio
    Hi Ruggerfly,
    If you haven't already, I suggest opening a case with F5 Support to get help troubleshooting this issue.
    Aaron
