Getting values of json from POST payload not working
Hi Guys,
strange behaviour down here. I'm trying to extract value of parameters from the payload of a POST and send with HSL using the below irule with no success at all: the variables are empty.
Can anyone tell me what's wrong with it?
set hsl [HSL::open -proto UDP -pool HSL]
set uri [HTTP::uri]
set ip [IP::client_addr]
if {[HTTP::uri] contains "keepal"} {
set data [HTTP::payload]
set namevals [split [HTTP::payload] "&"]
set a 0
set b 0
set c 0
set d 0
for {set i 0} {$i < [llength $namevals]} {incr i} {
set params [split [lindex $namevals $i] "="]
if { [lindex $params 0] equals "parA" } {
set a [lindex $params 1]
if { [lindex $params 0] equals "parB" } {
set b [lindex $params 1]
if { [lindex $params 0] equals "parC" } {
set C [lindex $params 1]
if { [lindex $params 0] equals "parD" } {
set d [lindex $params 1]
HSL::send $hsl "$ip|$a|$b|$c|$d"
- Kevin_Stewart
Employee
At a minimum you probably want to use the HTTP::collect command and HTTP_REQUEST_DATA event to capture the payload:when HTTP_REQUEST { if { ( [HTTP::method] equals "POST" ) and ( [string tolower [HTTP::uri]] contains "keepal" ) } { HTTP::collect [HTTP::header Content-Length] } } when HTTP_REQUEST_DATA { set payload [HTTP::payload] All collected payload is available here... }
You're most likely not seeing the payload in the HTTP_REQUEST event because it exceeds a single TCP packet. Using HTTP::collect tells the iRule to collect and buffer the payload (up to the specified amount) and make it available in the HTTP_REQUEST_DATA event. Take a look at the wiki for both of these (command and event) for more thorough implementations. - nitass
Employee
e.g.[root@ve10:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.252:80 ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve10:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { if {[HTTP::method] eq "POST"}{ if {[HTTP::header "Content-Length"] ne "" && [HTTP::header "Content-Length"] <= 1048576}{ set content_length [HTTP::header "Content-Length"] } else { set content_length 1048576 } if { $content_length > 0} { HTTP::collect $content_length } } } when HTTP_REQUEST_DATA { set a [URI::query "?&[HTTP::payload]" parA] set b [URI::query "?&[HTTP::payload]" parB] set c [URI::query "?&[HTTP::payload]" parC] set d [URI::query "?&[HTTP::payload]" parD] log local0. "a: $a b: $b c: $c d: $d" } } trace [root@ve10:Active] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 172.28.20.17(50767) <-> 172.28.19.252(80) 1375483782.1026 (0.0012) C>S --------------------------------------------------------------- POST / HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: 172.28.19.252 Accept: */* Content-Length: 38 Content-Type: application/x-www-form-urlencoded parA=one&parB=two&parC=three&parD=four--------------------------------------------------------------- /var/log/ltm [root@ve10:Active] config cat /var/log/ltm Aug 3 06:49:42 local/tmm info tmm[5139]: Rule myrule : a: one b: two c: three d: four
just a small comment. i think hsl::open should be done in CLIENT_ACCEPTED.
just my 2 cents.
