aj1's avatar
aj1
Sep 10, 2015
Getting the outside-to-inside NAT mapping using iControl
Trying to map an outside IP to an inside IP. I can get mappings the other way around, that is inside-to-outside, using
get_active_connection_v2
. The inside address is
cs-client-addr
and the outside is
ss-client-addr
I can use
cs-client-addr
as a parameter in
, but not
ss-client-addr
Example:
show /sys connection ss-client-addr 197.72.211.61
Sys::Connections
172.25.46.124%4:62262  107.21.224.38%4:443  197.72.211.61:1064  107.21.224.38:443  tcp  119  (slot/tmm: 1/0)  none
>>>import bigsuds
>>>b.System.Connections.get_active_connection_v2(cs_client, cs_server, protocol, ss_server)
        "clientside_bytes_in": {
            "high": 0,
            "low": 116
        "clientside_bytes_out": {
            "high": 0,
            "low": 60
        "clientside_packets_in": {
            "high": 0,
            "low": 2
        "clientside_packets_out": {
            "high": 0,
            "low": 1
        "connection_id": {
            "clientside_client": {
                "address": "172.25.46.124%4",
                "port": 62262
            "clientside_server": {
                "address": "107.21.224.38%4",
                "port": 443
            "protocol": "PROTOCOL_TCP",
            "serverside_server": {
                "address": "107.21.224.38",
                "port": 443
        "idle_time": 213,
        "idle_timeout": 213,
        "lasthop_info": "/Common/VLAN_4708 2c:11:62:75:b5:c1",
        "serverside_bytes_in": {
            "high": 0,
            "low": 60
        "serverside_bytes_out": {
            "high": 0,
            "low": 116
        "serverside_client": {
            "address": "197.72.211.61",
            "port": 1064
        "serverside_packets_in": {
            "high": 0,
            "low": 1
        "serverside_packets_out": {
            "high": 0,
            "low": 2
        "traffic_group": "/Common/traffic-group-1",
        "virtual_path": {
            "address": "0.0.0.0",
            "port": 0
Thanks in advance!
