splion_86861
Oct 18, 2011Get "unit id" from redundancy with iControl
how can i get the "Unit-ID" from the redundancy-section?
In the Web-Interface you can get the info with
System - High Availability - Redundancy - General Properties
bye Andreas
- Michael_Yates
Hi splion,
Try the get_platform_id (http://devcentral.f5.com/wiki/iControl.Management__Device__get_platform_id.ashx) method.
http://devcentral.f5.com/wiki/iControl.Management__Device.ashx - George_Watkins_Historic F5 AccountHi Splion,
I think this may be what you're looking for: http://devcentral.f5.com/wiki/iControl.Networking__SelfIP__get_unit_id.ashx
-George - splion_86861
thanks for your replies.
management::Device is a feature of iControl v11 but i use the v10.
The unit-id from SelfIP::get_unit_id is not the Unit-ID i need. I need the Unid-ID from the redundancy-section.
bye Andreas Splion,
you will find the HA unit id in the DB variable "Failover.UnitID". iControl gives access to the DB variables via Management::DBVariable::query.
Hope that helps.
Regards
Kurt Knochner
