FTP latency issue with LTM 1600
I am using LTM 1600 as a proxy server for services including FTP. The problem i am facing is the latency issue. Client is facing a delay of about 8 to 10secs per response from the server. Server has been checked, is there any thing that i am missing on F5 ? I am using parent FTP profile.
Thanks Kash.
- What_Lies_Bene1
I'd suggest you do a packet capture (including client and server side flows) using tcpdump and determine where the delay occurs before assuming it's the F5. Post back if you want some help with syntax etc.
- Kashif_01_13494
Thanks. There is no delay if i FTP to server directly by passing F5. Hence my assumption. But i will get the tcpdump to confirm.
- What_Lies_Bene1
Fair enough. Is the path via the F5 significantly different (firewalls or whatever) of not so?
- Kashif_01_13494
nope, the path is same. Same firewalls and equipment.
- What_Lies_Bene1
OK. I think the capture is even more important then. Thanks
