sally_calvert_8
Oct 24, 2013foundry-to-F5 conversion
We have some aging foundry equipment which is failing. The F5s running version 10.2.4 are sitting right next to them but have never been implemented. I am doing the conversion - anyone know the F5 equivalent to "port ssl dsr fast-delete"? thanks.
- What_Lies_Bene1
I'm afraid I don't know but perhaps if you could explain what that command does I can help.
- sally_calvert_8
I have no idea! I looked it up on the brocade site, and it sounds like it bypasses the load balancer on the return traffic, which doesn't make sense (asymmetric routing?)
- What_Lies_Bene1
OK, I can't help then. BTW, in F5 terms it's called nPath.
- sally_calvert_8
that's what I needed. thanks.
- What_Lies_Bene1
You're welcome.
