jessbase1_25611
Mar 26, 2016Force Offline node stuck to 2 connections
I force offline one my node and waited for half an hour to make sure that the connections will be zero, but it still stuck in 2 connections. How will I know if these connections are active or legitimate?
- nathe
Cirrocumulus
They would have to be active else. Perhaps a long tcp idle timeout setting or a keepalive of some description.
Take a look at the output of:
Tmsh show sys conn cs-server-addr
That will at least identify the culprits.
Hope this helps,
N
