Michal_Seckar_3's avatar
Michal_Seckar_3
Jun 13, 2018
Filter to ASM does not work. Pls help
Hi all,
Can anyone help me out pls? Im trying to filter all events with raitings 4 or above. From documentation this url should be correct, but it does not work and wont filter anything/
https://ip_to_f5/mgmt/tm/asm/events/requests?$top=30&$filter=rating eq 4
Thank you in advance
  • nathe's avatar
    nathe
    Michael,
    You just need to build the logic in as rating is a sub-property of enforcementState, so this should work:
    mgmt/tm/asm/events/requests?$filter=enforcementState/rating ge 4)
    See if that helps,
    N
