Fredde_369832's avatar
Fredde_369832
Aug 14, 2018
Fan speed BIG-IP 7250V
Hi peeps!
I have a problem that i cant find a solution to. It is about the FAN speed on my BIG-IP 7250V.
Problem is that all the fans are spinning at full speed!
Chassis Fan Status
Index  Status  Low Limit(rpm)  Fan Speed(rpm)
1      up      1000            10764
2      up      1000            11619
3      up      1000            10764
4      up      1000            11437
CPU Status
Index  Temp(degC)  Fan Speed(rpm)
1      42          11619
One thing i cant understand is why the system thinks i have a CPU fan? Cause i dont, i only have a CPU heatsink on it.
My BIG-IP version is: BIG-IP 13.1.0.8 Build 0.0.3 Point Release 8.
Anyway have any clue on how i can fix this? Cause it is really loud!
  • One thing i cant understand is why the system thinks i have a CPU fan?
    Basically, the registers for a CPU fan are present on the system, even if the fan itself is not present. The query reports a static number.
    Platform Guide: 7000 Series
    Acoustic specifications
    Front 67dBA
    Back 78dBA
    Left 66dBA
    Right 69dBA
    Top 69dBA
    These systems are about as loud as a large vacuum cleaner.
