mrp_235984
Jun 17, 2016Failover state
If I reboot the standby device (and do nothing to the active device), after the device is rebooted would it remain the standby device? Or would a failover occur?
- Hannes_Rapp
It really depends on HA configuration. I recommend you use the
state, this will ensure your unit will not process any traffic so you will not have to be concerned about possible impact due to reboot.Force Offlinehttps://support.f5.com/kb/en-us/solutions/public/15000/100/sol15122.html
