Failover and Failback between pools using % availability
We are migrating from Cisco ACE to f5 Load balancer.
We have configuration in ACE - there is primary pool(4 members) and backup pool(2 members).
In ACE: partial-threshold 49 back-inservice 99
Above command on the CISCO ACE will be send all traffic to the primary pool and in an event when there is less than 3 servers available on primary pool i.e., less than 49% availability the traffic will switch to the backup pool.
Traffic will failback to the primary pool only when there is more than 99% availability on the primary pool. i.e., all the members are avaiable.
Is it possible to achieve this scenario using iRULE and by calculating the % availablility on the pools to trigger failover and failback?
I don't think you will need an iRule to match this configuration. Did you took a look at priority group activation? See:
Hi Kram,
based on the answer i gave you a few weeks ago...
https://devcentral.f5.com/questions/pool-member-failback-condition-48341
... the required iRule would look like that...
when RULE_INIT { set static::primary_pool "pool_a" set static::primary_failover_value 49 set static::primary_failback_value 99 set static::backup_pool "pool_b" } when CLIENT_ACCEPTED { Check session table if backup mode is currently active if { [table lookup "status_$static::primary_pool"] eq "backup" } then { Backup mode is currently active. Applying Backup mode availability requirements. Check if primary pool has equal or more than 4 members. if { [expr { 100 / [members $static::primary_pool] * [active_members $static::primary_pool] }] >= $static::primary_failback_value] } then { Primary pool has equal or more than 4 members. Switching back to primary pool and disable Backup mode. table delete "status_$static::primary_pool" pool "$static::primary_pool" } else { Primary pool has less than 4 members. Using backup pool and keeping Backup mode active... pool "$static::backup_pool" } } else { Backup mode is currently not active (default). Applying normal availability requirements. Check if primary pool has more than 1 members. if { [expr { 100 / [members $static::primary_pool] * [active_members $static::primary_pool] }] > $static::primary_failover_value] } then { Primary pool more than 1 member. Using primary pool and keeping Backup mode disabled... pool "$static::primary_pool" } else { Primary pool less than 2 available member. Using the backup pool and enable Backup mode in session table... table add "status_$static::primary_pool" "backup" indefinite indefinite pool "$static::backup_pool" } } }Note: The iRule uses a
syntax to calculate the % availability of your primary pool. The value is then compared using a simply[expr { 100 / [members $static::primary_pool] * [active_members $static::primary_pool] }]
comparsion with the configured failover/failback value.>=Note: The additional % value calculation requires additional CPU cycles. Using hardcoded failover/failback values has a much lower CPU overhead.
Cheers, Kai
