Pradeep_Kandala's avatar
Pradeep_Kandala
Nov 02, 2012
Facing issue in HTTP::collect, HTTP::payload
Hi Guys,
I have a nice working IRULEs code, but for my additional operations, I'm trying to fetch the complete body from post method using the below code.. but it hangs when I add the code.
I'm not finding the proper literature which gives clear idea to use HTTP::collect and HTTP::payload
in HTTP_REQUEST
if {[HTTP::method] equals "POST"} {
if {[HTTP::header Content-Length] > 1 && [HTTP::header Content-Length] < 7000} {
set content_length [HTTP::header Content-Length]
Use default collect length
[HTTP::collect [HTTP::header Content-Length]]
log local0.info "10.0023- Printing the SAML response: $SAMLResponse IP: [IP::client_addr]"
when HTTP_REQUEST_DATA {
do stuff with the payload
set SAMLResponse [HTTP::payload]
log local0.info "60.0000- Printing the SAML response: $SAMLResponse IP: [IP::client_addr]"
HTTP::release
Thanks a lot in advance,
Pradeep
  • [HTTP::collect [HTTP::header Content-Length]]i do not think you need outer bracket.
    these are more examples. the latter one is to collect response, so you have to modify it for request.
    HTTP::collect Wiki
    https://devcentral.f5.com/wiki/irules.HTTP__collect.ashx
    HTTP Payload Collection CodeShare by Deb
    https://devcentral.f5.com/wiki/iRules.HTTPPayloadCollection.ashx
  • That was not the issue, its not working if length is above 200, the data ai send is more than 5500. not able to get the resolution
