kridsana_52318's avatar
kridsana_52318
Jun 02, 2014
F5 Sync Problem v. 11.4.1
Hi everyone
I've some problem about sync
I can't sync F5 module APM v.11.4.1 HF2 which reside on differrent site
When I add peer apm, Log shown
"Can't connect to CMI peer x.x.x.x, port:6699, Transport endpoint is not connected"
What does it mean ?
ps. Before add peer , we can iquery to each other. but after add peer we can't iquery anymore.
Thank you in advance
  • My college has do something and we seem to passed this problem (I'll ask him detail and share with all of you around next week)
    But we face another problem
    When we tried to sync >> It show sync failed and log show about "master decrypt fail during rekey"
    So I want to rekey by "f5mku -r [keyofpeerunit]"
    Problem is error occur >>> "master decrypt failed during rekey"
    Anyone experience this problem?
    Thank you
  • Hi Teepan,
    After reading the above thread I m assuming that there are only two devices in the Sync-Failover group. Have you tried by resetting the device trust and removing the devices from Syn-failover group, delete the existing sync-failover group and start from scratch everything (Follow the right steps or the document).
    I believe it should work.
    Regards.
  • When we tried to sync >> It show sync failed and log show about "master decrypt fail during rekey"
    can you try to delete configuration on standby which requires passphrase (e.g. delete ltm virtual, delete ltm profile client-ssl, delete ltm profile server-ssl) then re-key (e.g. f5mku) and configsync?
    • kridsana's avatar
      kridsana
      You are right, We try to delete many configuration and see the problem happen with apm "rewrite profile" . When we delete rewrite profile and try to rekey ... It's working now..
    • kridsana's avatar
      kridsana
  • Right now We can sync properly with some limitation
    1. we can sync from external (public IP)
    2. We can't sync via internal IP (Differrent site but can routable) . This is due to Active-Active Firewall that reside in customer network and behavior when add peer of F5
    for choice 2 ...I'll open case and collect more information and let you know.
    Thank you very much
  • I know this is an old thread but I root cause in our case was that the physical switch in the vCenter had been changed/altered and no longer contained all the necessary VLANs.
    In our case at least, the BigIP instances could find each other without a problem but would not sync, regardless of what we did. Both were 'Active' and 'Disconnected'.
    Hope it helps someone.
