Santiago_Marti1
Apr 10, 2014F5 Monitor SSL - Chain.
Hi All, do you know if its possible to specify a CAfile for a specific monitor/heathcheck? I tested the crt/key and are correct, but need to specify the ca as openssl cant validate the issuer. If I run it from cli (curl/openssl) works great but no luck with the F5 monitors.. Best regards.
- nag_54823
we don't have any option in monitor to mention CAfile
