Shamsul_Alam_34
7 years agoF5 LTM open connection
Currently we are load balancing our public portal using F5 LTM. We use client ssl offload. Based on the F5 LTM connection status, I can see 6 connections are made for single login process. Can any one help to explain why F5 LTM showing total 6 connection for single login? .
[sh@f501:Active:In Sync] ~ tmsh show sys conn cs-client-addr 139.60.XXX.XXX
Sys::Connections
139.60.XXX.XXX:54284 172.16.5.18:443 172.16.5.19:54284 172.16.5.76:80 tcp 5 (tmm: 0) none
139.60.XXX.XXX:24301 172.16.5.18:443 172.16.5.19:24301 172.16.5.76:80 tcp 5 (tmm: 1) none
139.60.XXX.XXX:2402 172.16.5.18:443 172.16.5.19:2402 172.16.5.76:80 tcp 5 (tmm: 1) none
139.60.XXX.XXX:7585 172.16.5.18:443 172.16.5.19:7585 172.16.5.76:80 tcp 5 (tmm: 0) none
139.60.XXX.XXX:21189 172.16.5.18:443 172.16.5.19:21189 172.16.5.76:80 tcp 5 (tmm: 1) none
139.60.XXX.XXX:49422 172.16.5.18:443 172.16.5.19:49422 172.16.5.76:80 tcp 5 (tmm: 1) none
Thanks in advance.
