Jatinder_383355's avatar
Jatinder_383355
Feb 09, 2019
F5 LTM Home Lab Issue
I setup this F5 home lab using vmware workstation. Key notes:
1) Servers are running Win-7 (iis & hosting local website for testing) 2) All of the F5 LTM interfaces are assigned to appropriate VMNet vlans & are showing up.
Issues: 1) F5 is not able to ping the inside servers but inside servers are able to ping the F5 LTM inside ip(10.0.0.105).
2) Servers cannot ping each other. For this reason I cannot check if the website hosted on them is working.
Please suggest on what changes I need to make in lab to get this working
Thanks JS
  • Maybe Win7 Firewall is blocking ping requests. If not, start tcpdump on F5 and capture traffic for troubleshoot.
  • Hamish's avatar
    Hamish
    The note that the two windows boxes can't ping each other suggests to me that the fault is at the windows boxes.
    You can verify this by performing a tcpdump at the BigIP. If you see ICMP echo-requests leaving the internal interface and no reply, that's a smoking gun.
    Check your windows firewalls...
    H
  • Man you need to put some more details like
    tmsh list ltm vlans
    tmsh list ltm self-ip
    tmsh list ltm virtual
    and try this pcap
    tcpdump -nni 0.0:p host  or host  -w /var/tmp/f5lab.pcap
    Then get the capture from winscp.
    Check the routes on the backend server if they have f5 as the default gateway. If not then you need to enable
    SNAT: auto
    map in the virtual server option.
    cheers!
