junior's avatar
junior
Jul 17, 2019
F5 IRULE cannot use [LB::server pool] in FLOW_INIT context
Anyone know why I cannot use [LB::server pool] in FLOW_INIT context it works fine in HTTP_REQUEST? Is there a way to get pool name attached to VIP in RULE_INT don't want to hard code pool name.
  • Hi.
    According to the cloud doc, [LB::server] command is valid in the following events.
    But "FLOW_INIT" is not listed in events.
    https://clouddocs.f5.com/api/irules/LB__server.html
    Related Information
    Valid Events:
    CLIENT_ACCEPTED, HTTP_REQUEST, HTTP_RESPONSE, LB_FAILED, LB_SELECTED
  • JG's avatar
    JG
    Why do you need to use [LB::server pool] in the FLOW_INIT event?
  • junior's avatar
    junior
    need to send rejection packet when servers are down on VIP. I have over 10 VIPs to apply this to due to external monitors. Anyway to dynamically get the pool value in FLOW_INIT
  • JG's avatar
    JG
    As the linked article above describes, the purpose of the FLOW_INIT event is for the following use cases:
    • Override ACL action
    • Bandwidth control on both client/server flows
    • Routing to another Vip
    • Marking qos tos/dscp on both client/server flows
    So you will need to move up to the application layer to be able to use [LB::server pool] .
  • junior's avatar
    junior
    if I move this to application layer and this is just a regular TCP VIP with standard profile then theres no way to stop the 3 way handshake unless its done in FLOW_INIT..Unless i am missing something
  • JG's avatar
    JG
    If you are thinking of evaluating the pool status at the very first client packet (if you could do that - you can't), then you are not really saving a significant amount of resources; instead you are making your F5 system more vulnerable in a possible syn attack.
  • junior's avatar
    junior
    so what is the best way to drop a tcp connection on a VIP with Standard profile when no pool members are up...Our external monitors are having false positives. F5 article said to use this approach.
  • JG's avatar
    JG
    In the event "CLIENT_ACCEPTED".
    Health monitor is a different issue. Is there something special that you need to use an external monitor for it?
