antesmol's avatar
Jun 11, 2026
F5 https monitor receive string
Hello,
I am testing an HTTPS monitor on BIG-IP 17.1.2.
The server endpoint returns:
HTTP/1.1 200 OK when the service is healthy
HTTP/1.1 503 Service Unavailable when the service is unhealthy
This behavior has been confirmed from the F5 using:
curl
In the HTTPS monitor, I tried the following Receive Strings:
-HTTP/1.1 200
-200 OK
- HTTP 200
but the monitor stays DOWN.
If I use:
-ok||200
the monitor goes UP, however it also remains UP when the endpoint returns HTTP 503.
My question is:
How can I configure a standard HTTPS monitor so that it is UP only when the endpoint returns HTTP 200 and DOWN when it returns HTTP 503?
Thank you.
