Slevi's avatar
Slevi
Feb 03, 2024
F5 CSPM injected and then appears in an input field
Hi Guys!
I have a website where i injected the F5 CSPM analytics code, everything is good no problem.
The problem is where i would like to write to an input field the javascript code just appears there
What do you think how can i solve this problem?
Thank you!
  • Are you using a web framework (virtual DOM), or JS DOM manipulation (maybe populating it based on a JS variable) to build the input, or just plain HTML? Can you share the original web page code so we can see how that select box is constructed and try to reproduce the issue?
