kridsana_52318
Sep 22, 2016F5 11.5.4 SSH issue
Hi
Did anyone have a problem with 11.5.4 HF2 ?
I've create SSH virtual server and pool member is also port 22
But "some" client can't access this virtual.
I didn't see known issue about ssh in 11.5.2 HF2 though.
Ker
- Henry_Chong_154
Altocumulus
A bit more info to the problem?
i) Are the clients accessing through the same IP ranges/VLAN sections?
ii) Type of software client using possibly
- tatmotiv
If this affects only some clients, you might want to check if the connection attempts of those clients reach your BigIP at all. I would start by doing a
. If you can see the connections arrive, the problem is probably in the big-IP config (limited source IPs, VLAN-allow settings, iRules...). If you do not see any packets arrive on your side, I'd check the client and/or intermediate devices (e.g. firewalls).tcpdump -i clientside-vlan host vip-ip and host client-ip and port 22
