Chirag_Mehta_15's avatar
Chirag_Mehta_15
Jul 15, 2011
Extract CSR for SSL Certificate
Please can someone advise as to how one can extract the CSR (Certificate Signing request) file for a SSL certificate on the BIG IP F5
  • Hamish's avatar
    Hamish
    A previous one? You can't. AFAIK it's not saved anywhere.
    You can however generate a NEW CSR for an existing key. But if your aim is to get a certificate renewal, I'd recommend generating a NEW keypair and use the CSR from that. (There's no real requirement to get a copy of a CSR. It's only of use to request a signed certificate from a CA. Once signed, you just need the cert and the private key).
    H
  • Hamish's avatar
    Hamish
    Actually... I lie...
    BigIP (10.2.1) saves the CSR's in /config/ssl/ssl.csr
    H
  • Hi,
    Yes I am trying to generate a CSR for renewal of an existing certificate. So do I need to export the existing Key ti get there.
    There is an option to "Renew" how will that work
  • hoolio's avatar
    hoolio
    Hi Chirag,
    Clicking renew will generate a new CSR with the existing key. If you want to create a new key and CSR, you can use this process:
    sol7573: Renewing a Certificate Authorities signed certificate that requires a new key without overwriting the current key and certificate
    http://support.f5.com/kb/en-us/solutions/public/7000/500/sol7573.html
    And be aware of this:
    sol10561: The BIG-IP system may not use a renewed SSL certificate
    http://support.f5.com/kb/en-us/solutions/public/10000/500/sol10561.html
    Aaron
  • Hamish's avatar
    Hamish
    I always insist on a new keypair... It's no trouble to do and so much safer if old backups etc get compromised.
    You also get to increase the keylength...
    H
  • The CSR can be generated by creating a new SSL certificate. Go to LTM, SSL Certificates & then select create & once you press finish after filling in the details a CSR is generated which can be used for getting the certificate from the Certificate Authority e.g. Verisign.
