Kirit_Patel_521
Mar 09, 2011Equivalnet of flow timeout-multiplier command in f5
ALL
In cisco CSS there is a command flow-timeout-multiplier which specifies number of seconds for which an idle flow can exists before the load balancer tears it down. Whats the equivalent in f5 ltm?
- Chris_Miller
Altostratus
I believe you want the TCP Idle Timeout which can be found in your "Local Traffic" -> "Profiles" -> "Protocol" -> "TCP" section in the GUI.
